Bulk deletion for unassigned device profiles on CUCM 9.1.1
Hi, everybody,
I need some help on CUCM 9.1.1
I have to perform a bulk deletion of unassigned device profiles.
Can you tell me how to do this task ?
I really appreciate your help, guys.
Best regards.
Use BAT to delete the UDPs.
java
if this helps, please rate
www.cisco.com/go/pdi
thanks, Jaime, for your
thanks, Jaime, for your answer,
I want to delete a huge number of unassigned device profiles (about a two hundred or more)
I tried to use BAT, but there is no filter to show the unassigned device profiles to end users.
I was thinking some kinda sql CLI command that'll do the trick.
any leads, please ??
Hi.You can export all UDP
Hi.
You can export all UDP.
Edit it with Excel
filter only entries with empty user
Upload the modified file as UDP- UDP Delete Custom File
Select delete device profile from BAT menu
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks, CarloI'll try that
Thanks, Carlo
I'll try that method and I'll let you know.
Best regards.
69
