Bulk Edit for Call Handlers in 8x Unity Connections
Dear Friends,
I need to edit theCall handlers in bulk say I have 650 CHs pointing to various CHs and Subscribers. I would like to change the CH ext from 10 digit to 7 digit number. Is there any way to edit it using the Bulk edit? I do not see an option on the Bulk Admin Tool in the Connections.
Please help!
Mohsin..
1 REPLY
Would you consider using COBRAS to export all of them and edit the resulting DB.  Then you could re-import them with their new configuration and remove the old.  Never tried this, just thought I would comment.
145
