Bulk FXO device?
My customer is intended to run FXO instead of PRI for billing purpose. They need 48 Port FXO termination. I fear  that VG-248 is intended for FXS termination. Is there any device  available to serve this purpose?
1 REPLY
Re: Bulk FXO device?
By billing I assume you mean cost?  You are correct the VG248 will not help you.  You would need a high density FXO or DID solution (depending on what you need and how you configure trunks from carrier).  Take a look here:
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/exvoimod.html
http://www.cisco.com/en/US/products/hw/modules/ps2617/products_configuration_example09186a0080513001.shtml
Analog DID requires you to order that particular service from your carrier.  I haven't used these interfaces in production (well, not as analog DID anyway).  So you may want to research that a little.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
246
