01-28-2007 03:04 PM - edited 03-14-2019 07:46 PM
Is there a way to bulk import route patterns? We use a very consistant pattern of numbers for outdialing, and blocked patterns, and I'd like to automate the installation.
Is there a way?
01-28-2007 03:07 PM
There are a couple of good axl tools at the which allow you to import/export route
patterns and translation patterns. Using AXL is the way to go.
You may open a TAC case for this one or maybe in the IP telephony for Developers you will find it.
01-28-2007 06:56 PM
Where can I get this? I'll dig in the developers area, but if you have a direct link to the tools that would be great.
01-28-2007 08:10 PM
Ok, I reviewed the AXL/Soap areas. What I'm really looking for is a quick way to take a CSV file etc and push it to the callmanager database with the new route patterns.
Anyone have a axl script already set for that?
02-02-2007 10:16 AM
Mike,
I am in the same boat...Did you find any good links on this topic?...Thanks
03-21-2007 08:56 PM
Anyone figure this out? I have 350 route patterns I have to create.
05-02-2008 11:24 AM
I see that I am digging up an old topic but has anyone found a solution for this?
11-07-2013 05:36 PM
Can we do this in CUCM 8.5? I still can not see template for importing Route patterns.
