Bulk import of Router pattern in CUCM 8.5
As the subject explains, Is it possible to bulk import of Router Patterns?
  • IP Telephony
Hall of Fame Super Silver
Yes, use the export/import feature of BAT.
Chris
I did try that
-- Exported the Route Patterns File
--- Updated the Route Pattern File with new route patterns
--- Converted the csv file into tar and upload it to CUCM
--While uploading i selected the Target "Import/Export" and Transaciton type "Import Configuration"
-- Executed the file after validating it
-- In the job Shceduler it states that the job was completed successfully and records updated "150" which are the number of route patterns i am trying to add but when i look in the route patterns there is nothing in the list.
What is the version of CUCM ?
-Sandesh Rao
8.5.1
148
