Bulk import users from AD
Ok, so there are a few threads around that talk about this topic but it seems like either I am missing something or I am confused...
I want to bulk import users from AD. Similar to how I would do a single user (Users> Import).
I have followed to the guidelines here:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmac105.html
My problem is that when I export users, modify the csv file and re-import it, it does create a user with a mailbox but it is not a User that is imported from AD..?
If I look at any user that I have successfully imported from AD, there is a status message that says "Active User Imported from LDAP Directory"
Anyone any idea how I would bulk create users that will be imported from AD...
Hall of Fame Super Silver
Re: Bulk import users from AD
can you post your import file?
sure, here you go...
You need to set the "LdapCcmUserId" as well as the Alias.
HTH, please rate all useful posts!
Chris
191
