Bulk updating Alerting names in CCM5.1.2
My customer has just decided (near project end!) that they'd like the names to show on the displays when an internal call comes in. I know this means that I have to configure the Alerting Name on each line. But with some 290 phones to do, is there a quicker way to do it?
I can't seem to figure out how to use BAT to accomplish this.
I'm not using AD.
Any help gratefully appreciated!
Dan
Silver
Re: Bulk updating Alerting names in CCM5.1.2
No (BAT) other bulk method would be a custom SQL query but that's unsupported.
i know it's not TAC supported but i did something similar a while ago with CCM 4.1(3)
i created this qry which copied the description that comes in the device config into the label for the line
update devicenumplanmap
set devicenumplanmap.label = device.description
from device
INNER JOIN devicenumplanmap on device.pkid=devicenumplanmap.fkdevice
In order to change the alerting name you would need to reference:
Table -> NumPlan
Field -> AlertingName
it's trickier now using just the CLI but if you look into the DB dictionary for CUCM 5 you can probably use something similar.
AFAIK the DB structure is almost the same as with CCM 4.1(3) just some minor changes
java
if this helps, please rate
www.cisco.com/go/pdi
Guy's,
Thanks for the help. As I'm still relatively new to the IPT game, I think I need to stick TAC supported stuff until I'm a bit more savvy!
I got round this by getting the new guy to do it manually (gave him some good experience with the CCM 5 Interface!!)
Thanks again
Dan
Hi Daniel,
Did you resolved your problem?
I have same problem with CCM 6.0.
Thank you,
Cristian
137
