tka
Community Member
Bulk Voice Mail changing - Unity Connection
Is there a way to set a default Voice Mail Connection password for all users.As soon as the users dials the VoiceMail Hunt Pilot , he is asked to change his password.
thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Bulk Voice Mail changing - Unity Connection
Hi Ramzi,
For Unity Connection the default password for users is setup in the VM Template that is used to create new users :)
Do the following procedure for user accounts, or for a template that you will use to create user accounts.
To Change a Phone (PIN) Password for an Individual User or Template
Step 1 In Cisco Unity Connection Administration, find the template that you want to edit.
Step 2 On the Edit menu, click Change Password.
Step 3 In the Choose Password list, click Voice Mail.
Step 4 In the Password field, enter the new password.
Step 5 In the Confirm Password field, reenter the password to confirm.
Step 6 Click Save.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/user_mac/guide/2xcucmac040.html#wp1054468
Then check the option " User Must Change at Next Login" to force them to setup a new "personal" password.
Hope this helps!
Rob
Hi Tka,
I think it will be as i do in unity 4.0,
It is when you create the subscriber,
He will be assigned the password configured in the user conf page
And in his first access to unity, he will be asked to change his password by default
Wish this be helpful
tka
Community Member
Hi ,
First ,thansk for your reply
Actually, I'm talking about Unity Connection and not Unity so the concept of Subscriber is inexistant
regards,
Hi Ramzi,
Step 6 Click Save.
Hope this helps!
Rob
327
