Business attendant console
I have been looking through the cisco site to see what handsets are supported for a receptionists phone to use Business attendant console.
I was about to recommend 7962 but thought it best to check. Is there any documentation anywhere to say which phones will work. I seem to remember a couple of years ago, that you couldn't use 7931, so I want to make sure.
1 ACCEPTED SOLUTION
Re: Business attendant console
This is from Sept, 2009 but maybe it can help:
7940, 7941, 7942, 7945, 7960, 7961, 7962, 7965, 7970, 7971, 7975, IPC
Supported for any CUxAC
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Anyone?
Hall of Fame Super Red
Hey "P",
I spent at least an hour the other night (in the middle of an upgrade window)
looking for an answer to this question. Must have looked at 50 docs and never
saw any detailed specs for this If it were me I'd go with a 7965G, but you might
want to check with TAC.
Sorry man!
Cheers!
Rob
Thanks anyway Rob,
I thought I was going mad and just didn't look properly.
i'll check with TAC
java
java
Hey Java,
Nice work buddy! (+5 points for this!)
Cheers!
Rob
many thanks for the excellent help
389
