Business Edition 6000 HA
Is it possible to set up two BE6K's   in active/active configuration for CUC 9.1?
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
+5 for Rob for correct answer.
Think about BE6K as a solution with individual applications, so the redundancy would be at the application level where they can be spread between 2 BE6K UCS servers.
Chris
Hall of Fame Super Red
Hey Pete,
Yes, this is supported
Note
The  Connection cluster feature is supported for use with Cisco Unified  Communications Manager Business Edition 6000, however, it is not  supported with Cisco Unified Communications Manager Business Edition  3000 and Cisco Unified Communications Manager Business Edition 5000.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/design/guide/9xcucdg060.html
Cheers!
Rob
"Why do the best things always disappear "
- The Band
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Chris
Thank you both for the quick response.  I had a readup on the CUC 9.x clustering, and found this line about the CUC publisher responsibilities.
Homing and publishing the database and message store, which are both replicated to the other server.
thats the piece I couldnt get  a handle on.
thanks again
142
