ā02-22-2012 07:11 PM - edited ā03-16-2019 09:44 AM
Is it at all possible to intergrate Cisco Business Edtion 5000 with Microsoft Lync,
I have trolled, throught the system documentation and have yet to find any information that helps my cause.
Solved! Go to Solution.
ā02-22-2012 08:53 PM
CUCMBE runs CUCM under the hood, which can be integrated with Lync via SIP Trunk and/or CUCILYNC (http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/UC8.5.1/release_notes/rnipt851.html#wp1669174).
Here is a nice article on CUCM and Lync integration :
http://voipnorm.blogspot.com.au/2010/12/cisco-and-microsoft-lync.html
http://www.microsoft.com/download/en/details.aspx?id=26800
SIP Trunks do not deduct device licenses (DLUs) from the CUCMBE, but if you decide to use CUCILYNC, it will consume some DLUs.
Cheers,
Boris
ā02-22-2012 08:28 PM
Hi Luke,
Please elaborate on the integration requirements.
You can setup SIP Trunk and send calls between the systems, but I guess you are looking for something else, right?
Cheers,
Boris
ā02-22-2012 08:32 PM
Hi Boris,
What i am looking for is whether or not, Business Editon 5000 is at all compatiable with Lync.
as in is it the correct version or release of call manager
do i require a license for it to work with Lync
Cheers,
Boris
ā02-22-2012 09:00 PM
this has helped a lot
