Community Member
'Busy' indicator on 7915-24,
Hi all,
I have receptionist with 7961 + 7915-24. Some of the internal DNs are also shown on 7915-24 buttons. How do I allow the actual users make call and have the respective button on 7915-24 indicate busy or button change color to indicate in used. Can this be achieve? Please assist and advise.
Best regards,
Lawrence Chew
1 REPLY
If I follow what you are asking, the 7915 will do this "by default". The button changes color depending on line state:
1. Dark (no light/color): Line available
2. Green, steady: Line in use
3. Red, steady: Line in use on a different station (shared line appearance)
4. Amber, flashing: Line is ringing
5. Green, flashing: Line is on hold
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
210
