Busy Out a B Channel
I know I can busy out a Bchannel for MGCP in CCM through the service parameters is there a fast way to busy out Bchannels on the gateway. I need to just test one Bchannel on each of my PRI's so I need to Busy Out 22 of the b channels at a time on each PRI so I can test hunting to the next PRI.
1 REPLY
Hall of Fame Super Gold
Re: Busy Out a B Channel
Busy out on ISDN is not easy as it may seem.
When the call comes, in the setup message is already indicated a channel, either exclusive or preferential. That is, is the switch that decides on which channel the calls lands.
However, certain switches support service messages to allow individual B channel busy out.
Check:
http://cisco.com/en/US/products/ps6441/products_feature_guide09186a0080686068.html
358
