04-05-2010 01:22 PM - edited 03-15-2019 10:06 PM
One of our customers needs us to busy out there PRI's while they install voice firewalls. There running CUCM 4.1 and the gateways are all MGCP. I found the document below and I have a couple questions about the gateway reboot in step 6. Can I do this reboot ahead of time to get ready and is it safe to leave the settings after they do there install or should I change it back?
I hope you guys have done or seen this before.
Thanks, Mike
Solved! Go to Solution.
04-05-2010 01:26 PM
I don't think you need to reboot the physical gateway. You simply need to enable status polling on the MGCP endpoint (in CUCM configuration mode) and do a reset on the gateway from CUCM. No reboot should be necessary.
HTH.
Bill
04-05-2010 01:26 PM
HTH.
Bill
04-07-2010 01:25 PM
Thanks Bill.
