Bronze
Busy-Out PRI's on MGCP Gateway
One of our customers needs us to busy out there PRI's while they install voice firewalls.  There running CUCM 4.1 and the gateways are all MGCP.  I found the document below and I have a couple questions about the gateway reboot in step 6.  Can I do this reboot ahead of time to get ready and is it safe to leave the settings after they do there install or should I change it back?
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008076f8d2.shtml
I hope you guys have done or seen this before.
Thanks, Mike
1 ACCEPTED SOLUTION
Re: Busy-Out PRI's on MGCP Gateway
I don't think you need to reboot the physical gateway. You simply need to enable status polling on the MGCP endpoint (in CUCM configuration mode) and do a reset on the gateway from CUCM. No reboot should be necessary.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
HTH.
Bill
Bronze
Thanks Bill.
456
