Busy signal with incoming calls.
Hi all, I have a problem with the incoming calls. I hear only one tone and the next a busy signal. I don't know if the configuration is correct, the outgoing calls working fine.
The configuration of dial-peer.
voice-port 2/0
translate called 1
supervisory disconnect anytone
cptone ES
timeouts initial 3
timeouts interdigit 3
bearer-cap Speech
voice-port 2/1
dial-peer cor custom
dial-peer voice 1 pots
preference 1
destination-pattern T
progress_ind setup enable 3
progress_ind alert enable 8
direct-inward-dial
port 2/0
dial-peer voice 3 voip
preference 1
destination-pattern 918762551
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.0.14
dtmf-relay h245-alphanumeric
no vad
Many Thanks for all.
108
