Community Member
busy tone on registered ip phone
Hello guys,
     I have a problem related to an ip phone that can not make calls, this ip phone it is registered and also has the rigth privilegies to make the calls, this is an extract of the configuration (the ip phone get a busy tone when begins to dial a number):
THIS IS THE IP PHONE:
ephone-dn  16  dual-line
number 5907 no-reg both
pickup-group 1
label 5907
description Embarques
name Embarques
call-forward busy 6000
call-forward noan 6000 timeout 20
corlist incoming usuarios-oficina
hold-alert 30 originator
(IP PHONE IS REGISTERED)
AND THESE ARE THE DIAL-PEERS:
dial-peer cor custom
name vigilancia
name oficina
dial-peer cor list usuarios-vigilancia
member vigilancia
dial-peer cor list list-vigilancia
member vigilancia
dial-peer cor list usuarios-oficina
member vigilancia
member oficina
dial-peer cor list list-oficina
member oficina
dial-peer voice 9 pots
trunkgroup E1-ALESTRA
corlist outgoing list-oficina
description **LOCALES**
destination-pattern 9[1-9]......
dial-peer voice 901 pots
description **LDN**
destination-pattern 901[2-9].........
prefix 01
dial-peer voice 9044 pots
description **Celulares**
destination-pattern 904[45]..........
prefix 04
dial-peer voice 9001 pots
description ***LDI **
destination-pattern 9001[2-9].........
prefix 001
dial-peer voice 900 pots
description ***Mundiales ***
destination-pattern 900[2-9].T
prefix 00
dial-peer voice 911 pots
description *** Llamadas emergencia ***
destination-pattern 90[^014].
forward-digits 3
dial-peer voice 6000 voip
description ***Llamadas al CUE***
destination-pattern 600[0-7]
lpcor outgoing ild
session protocol sipv2
session target ipv4:10.100.16.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 8001 voip
destination-pattern 600[1-2]....
lpcor outgoing ild
incoming called-number 600[8-9]....
codec g711ulaw
no vad
dial-peer voice 90 pots
incoming called-number .
direct-inward-dial
dial-peer voice 90441 pots
corlist outgoing list-vigilancia
destination-pattern 90444421812318
forward-digits 13
dial-peer voice 90442 pots
destination-pattern 90444423980436
forward-digits 13
dial-peer voice 90443 pots
destination-pattern 90444421272791
forward-digits 13
dial-peer voice 90444 pots
destination-pattern 90444423380898
forward-digits 13
dial-peer voice 200 pots
service stcapp
port 0/3/0
dial-peer voice 201 pots
service stcapp
port 0/3/1
dial-peer voice 202 pots
service stcapp
port 0/3/2
dial-peer voice 203 pots
service stcapp
port 0/3/3
dial-peer voice 90445 pots
destination-pattern 90444421272788
forward-digits 13
dial-peer voice 90446 pots
destination-pattern 90444422315748
forward-digits 13
dial-peer voice 90447 pots
destination-pattern 90444423851748
forward-digits 13
dial-peer voice 90448 pots
destination-pattern 90443410206
forward-digits 13
dial-peer voice 90449 pots
destination-pattern 90444423560889
forward-digits 13
dial-peer voice 90450 pots
destination-pattern 90444123712
forward-digits 13
dial-peer voice 90451 pots
destination-pattern 90444423381109
forward-digits 13
dial-peer voice 90452 pots
destination-pattern 90444422006167
forward-digits 13
dial-peer voice 90453 pots
forward-digits 13
dial-peer voice 90454 pots
destination-pattern 90444422006044
forward-digits 13
dial-peer voice 90455 pots
destination-pattern 90444421477097
forward-digits 13
dial-peer voice 90456 pots
forward-digits 13
dial-peer voice 90457 pots
destination-pattern 90444421193667
forward-digits 13
dial-peer voice 90458 pots
destination-pattern 90444423380436
forward-digits 13
any idea? command? to search the solution? thanks a lot guys!
1 REPLY
Community Member
Phone could make calls after some restarts...
255
