Busy Trigger - Ip Phone CISCO 6921 and 6941 models
                   How Configure Call Waiting phone cisco 6941?
Hall of Fame Super Silver
When these phone first came out they were hard coded to 2/1 (max calls/busy trigger), however with newer CUCM update and phone firmware that was changed to similar behavior to other phones, and to my recollection the max is 12 calls.
HTH,
Chris
Hello Chris Deren,
I have version 8.5 of CUCM and 69xx ip phone model.
Marcus
Hi Chris,
After downloading the package will be necessary to update the firmware of the 69xx phones?
Thank you.
Marcus
Did you get this to work by
Did you get this to work by installing the device pack?
I'm running 8.5.1.16900-6 and firmware SCCP69xx.9-4-1-3SR1, but I didn't install the device pack.
Does the device pack have other code to enable this feature for 8.5.1?
Re: Busy Trigger - Ip Phone CISCO 6921 and 6941 models
No, firmware is included in the dev pack.
Beautifull!
Thank you very much.
296
