10-16-2013 10:42 PM - edited 03-16-2019 07:56 PM
Hi all,
I am configuring CUE 7.1 with CME. I can dial to voice mail number but busy tone responding. Pls review the log:
CUE1# show trace buffer tail
Press <CTRL-C> to exit...
5011 10/17 11:37:59.829 ACCN EXMG 0 STANDARD-worker-8:Finished work
3626 10/17 11:38:04.197 WFSP APP 0 WFSysdbNdApp::get enter
3626 10/17 11:38:04.198 WFSP APP 0 WFSysdbNdApp::get appName=autoattendant attribute=enabled
3626 10/17 11:38:04.198 WFSP APP 0 WFSysdbNdApp::get exit
17419 10/17 11:38:04.810 ACCN COMG 0 Contact-21:Enter clockDaemon.run()
17419 10/17 11:38:04.810 ACCN SSCM 0 ICDContactAdapter 20 : ContactRejected received for App FW contact 21, iefSourceContact is 21 [BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59] (20)
17419 10/17 11:38:04.810 ACCN SSCM 0 ICDContactAdapter 20 .contactRejected () has ICDContactAdapter as inactive
17419 10/17 11:38:04.810 ACCN SSCM 0 ContactMgr.getResourceFromContact(BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59) returns null
17419 10/17 11:38:04.810 ACCN SSCM 0 channelImplId is null in ICDContactAdapter 20 .contactRejected (21, 21 [BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59])
17419 10/17 11:38:04.810 ACCN EXMG 0 Hiring :STANDARD-worker-8
17419 10/17 11:38:04.810 ACCN EXMG 0 STANDARD-worker-8:Assinged work
17419 10/17 11:38:04.810 ACCN COMG 0 Contact-21:Leave clockDaemon.run()
5011 10/17 11:38:04.810 ACCN EXMG 0 STANDARD-worker-8:Started work
5011 10/17 11:38:04.810 ACCN EXMG 0 start executing worklist
5011 10/17 11:38:04.810 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= POSTING_EVENT Task=com.cisco.app.subsystem.SubsystemApp$3@fd40fd4 starting task
5011 10/17 11:38:04.811 ACCN LEVT 0 POSTING_EVENT:: Event=com.cisco.call.CallEvent[CALL_REJECTED,state=CALL_REJECTED,reason=1,exception=null,reason=CHANNELS_BUSY,contactImplId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,lastContactImplId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,session=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],lastSession=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],contactSeqNum=0,lastContactSeqNum=0] on SIPCallContact[id=21,type=Cisco SIP Call,implId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,active=false,state=CALL_REJECTED,inbound=true,handled=false,locale=en_US,aborting=false,app=App[name=voicemail,type=Cisco Script Application,id=2,desc=voicemail,enabled=true,max=10,valid=true,optional=[cfgVars=[Lcom.cisco.wfapi.util.WFNameValuePair;@4f564f56,privilegeType=1,last.modified=1381836999105,script=voicebrowser.aef]],task=null,session=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],seqNum=0,time=1381984679716,cn=1000,dn=null,cgn=2000,ani=null,dnis=null,clid=sip:2000@10.15.242.59,atype=DIRECT,lrd=null,ocn=1000,odn=null,uui=null,aniii=null,ced=null,lrvmn=null,ocvmn=1000,route=TR[num=1000],port=null,aborting=false,transferring=false,disconnecting=false] at Thu Oct 17 11:37:59 GMT+07:00 2013
5011 10/17 11:38:04.811 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= POSTING_EVENT Task=com.cisco.app.subsystem.SubsystemApp$3@fd40fd4 finished task
5011 10/17 11:38:04.811 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= POSTED_EVENT Task=com.cisco.app.subsystem.SubsystemApp$3@11381138 starting task
5011 10/17 11:38:04.812 ACCN LEVT 0 POSTED_EVENT:: Event=com.cisco.call.CallEvent[CALL_REJECTED,state=CALL_REJECTED,reason=1,exception=null,reason=CHANNELS_BUSY,contactImplId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,lastContactImplId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,session=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],lastSession=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],contactSeqNum=0,lastContactSeqNum=0] on SIPCallContact[id=21,type=Cisco SIP Call,implId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,active=false,state=CALL_REJECTED,inbound=true,handled=false,locale=en_US,aborting=false,app=App[name=voicemail,type=Cisco Script Application,id=2,desc=voicemail,enabled=true,max=10,valid=true,optional=[cfgVars=[Lcom.cisco.wfapi.util.WFNameValuePair;@4f564f56,privilegeType=1,last.modified=1381836999105,script=voicebrowser.aef]],task=null,session=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],seqNum=0,time=1381984679716,cn=1000,dn=null,cgn=2000,ani=null,dnis=null,clid=sip:2000@10.15.242.59,atype=DIRECT,lrd=null,ocn=1000,odn=null,uui=null,aniii=null,ced=null,lrvmn=null,ocvmn=1000,route=TR[num=1000],port=null,aborting=false,transferring=false,disconnecting=false] at Thu Oct 17 11:37:59 GMT+07:00 2013
5011 10/17 11:38:04.812 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= POSTED_EVENT Task=com.cisco.app.subsystem.SubsystemApp$3@11381138 finished task
5011 10/17 11:38:04.812 ACCN EXMG 0 QueuedExecutorWorkList : WorkerName =null Current WorkOrder =null finished executing worklist
5011 10/17 11:38:04.812 ACCN EXMG 0 STANDARD-worker-8:Finished work
4985 10/17 11:38:04.812 ACCN EXMG 0 Hiring :STANDARD-worker-8
4985 10/17 11:38:04.812 ACCN EXMG 0 STANDARD-worker-8:Assinged work
4985 10/17 11:38:04.812 ACCN RTRS 0 CoreReportDataManager.contactRejected() called.
4985 10/17 11:38:04.812 ACCN EXMG 0 Hiring :STANDARD-worker-7
4985 10/17 11:38:04.812 ACCN EXMG 0 STANDARD-worker-7:Assinged work
5010 10/17 11:38:04.812 ACCN EXMG 0 STANDARD-worker-7:Started work
5010 10/17 11:38:04.812 ACCN EXMG 0 start executing worklist
5010 10/17 11:38:04.812 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= CONTACT_REJECTED Task=com.cisco.wf.subsystems.corereporting.CoreReportDataManager$11@3e283e28 starting task
5010 10/17 11:38:04.812 ACCN RTRS 0 CoreReportDataManager.contactRejected(). typeKey is CallContact className is com.cisco.call.CallContact
5011 10/17 11:38:04.812 ACCN EXMG 0 STANDARD-worker-8:Started work
5011 10/17 11:38:04.812 ACCN EXMG 0 start executing worklist
5011 10/17 11:38:04.812 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= DISPATCHING_EVENT Task=com.cisco.app.subsystem.SubsystemApp$3@3c923c92 starting task
5011 10/17 11:38:04.814 ACCN LEVT 0 DISPATCHING_EVENT:: Event=com.cisco.call.CallEvent[CALL_REJECTED,state=CALL_REJECTED,reason=1,exception=null,reason=CHANNELS_BUSY,contactImplId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,lastContactImplId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,session=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],lastSession=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],contactSeqNum=0,lastContactSeqNum=0] on SIPCallContact[id=21,type=Cisco SIP Call,implId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,active=false,state=CALL_REJECTED,inbound=true,handled=false,locale=en_US,aborting=false,app=App[name=voicemail,type=Cisco Script Application,id=2,desc=voicemail,enabled=true,max=10,valid=true,optional=[cfgVars=[Lcom.cisco.wfapi.util.WFNameValuePair;@4f564f56,privilegeType=1,last.modified=1381836999105,script=voicebrowser.aef]],task=null,session=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],seqNum=0,time=1381984679716,cn=1000,dn=null,cgn=2000,ani=null,dnis=null,clid=sip:2000@10.15.242.59,atype=DIRECT,lrd=null,ocn=1000,odn=null,uui=null,aniii=null,ced=null,lrvmn=null,ocvmn=1000,route=TR[num=1000],port=null,aborting=false,transferring=false,disconnecting=false] at Thu Oct 17 11:37:59 GMT+07:00 2013
5011 10/17 11:38:04.814 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= DISPATCHING_EVENT Task=com.cisco.app.subsystem.SubsystemApp$3@3c923c92 finished task
5011 10/17 11:38:04.814 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= DISPATCHED_EVENT Task=com.cisco.app.subsystem.SubsystemApp$3@3f8c3f8c starting task
5011 10/17 11:38:04.815 ACCN LEVT 0 DISPATCHED_EVENT:: Event=com.cisco.call.CallEvent[CALL_REJECTED,state=CALL_REJECTED,reason=1,exception=null,reason=CHANNELS_BUSY,contactImplId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,lastContactImplId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,session=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],lastSession=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],contactSeqNum=0,lastContactSeqNum=0] on SIPCallContact[id=21,type=Cisco SIP Call,implId=BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59,active=false,state=CALL_REJECTED,inbound=true,handled=false,locale=en_US,aborting=false,app=App[name=voicemail,type=Cisco Script Application,id=2,desc=voicemail,enabled=true,max=10,valid=true,optional=[cfgVars=[Lcom.cisco.wfapi.util.WFNameValuePair;@4f564f56,privilegeType=1,last.modified=1381836999105,script=voicebrowser.aef]],task=null,session=Session[id=0x15,parent=null,active=true,state=SESSION_IDLE,time=1381984679718],seqNum=0,time=1381984679716,cn=1000,dn=null,cgn=2000,ani=null,dnis=null,clid=sip:2000@10.15.242.59,atype=DIRECT,lrd=null,ocn=1000,odn=null,uui=null,aniii=null,ced=null,lrvmn=null,ocvmn=1000,route=TR[num=1000],port=null,aborting=false,transferring=false,disconnecting=false] at Thu Oct 17 11:37:59 GMT+07:00 2013
5011 10/17 11:38:04.815 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= DISPATCHED_EVENT Task=com.cisco.app.subsystem.SubsystemApp$3@3f8c3f8c finished task
5011 10/17 11:38:04.815 ACCN EXMG 0 QueuedExecutorWorkList : WorkerName =null Current WorkOrder =null finished executing worklist
5011 10/17 11:38:04.815 ACCN EXMG 0 STANDARD-worker-8:Finished work
5205 10/17 11:38:04.816 ACCN SSCM 0 Processing msg: class com.cisco.wf.subsystems.rmcm.msgs.CMFireContactRejectedEventReqMsg Contact21
5205 10/17 11:38:04.816 ACCN SSCM 0 ContactMgrMsgProcessor.processRejectedEvReqMsg(21 [BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59], IAQ, Thu Oct 17 11:37:59 GMT+07:00 2013)
5205 10/17 11:38:04.816 ACCN SSCM 0 IEF Contact ID: [21] BC4546D6-361C11E3-8088F4BF-EDEDA4C2@10.15.242.59 ContactEventsGenerator: Posting the ContactRejectedEvent contact type IAQ session -1 session seq num 0
5205 10/17 11:38:04.816 ACCN EXMG 0 Hiring :STANDARD-worker-8
5011 10/17 11:38:04.817 ACCN EXMG 0 STANDARD-worker-8:Started work
5011 10/17 11:38:04.817 ACCN EXMG 0 start executing worklist
5011 10/17 11:38:04.817 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= POSTING_EVENT Task=com.cisco.app.subsystem.SubsystemApp$3@64f864f8 starting task
5011 10/17 11:38:04.817 ACCN LEVT 0 POSTING_EVENT:: Event=com.cisco.wf.subsystems.events.ContactRejectedEvent[] on com.cisco.wf.subsystems.rmcm.CallContact@71a071a0 at Thu Oct 17 11:37:59 GMT+07:00 2013
5011 10/17 11:38:04.817 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= POSTING_EVENT Task=com.cisco.app.subsystem.SubsystemApp$3@64f864f8 finished task
5205 10/17 11:38:04.817 ACCN EXMG 0 STANDARD-worker-8:Assinged work
4986 10/17 11:38:04.817 ACCN HRDM 0 contactRejected - contactID: 21, sessionSeqNr: 0, sessionID: 21
4986 10/17 11:38:04.818 ACCN HRDM 0 setCalledNumber: setting called number : 1000
4986 10/17 11:38:04.818 ACCN HRDM 0 setApplicationInfo
4986 10/17 11:38:04.818 ACCN HRDM 0 setApplicationInfo - appID= 2
4986 10/17 11:38:04.818 ACCN HRDM 0 setApplicationInfo - throws exception java.lang.NullPointerException
4986 10/17 11:38:04.818 ACCN HRDM 0 writeCCDRToDatabase
5204 10/17 11:38:04.818 ACCN ENGN 0 Record 436345346 enqueued. Queue size=0 total number of writes=21
3624 10/17 11:38:04.826 WFSP APP 0 WFSysdbNdApp::get enter
3624 10/17 11:38:04.826 WFSP APP 0 WFSysdbNdApp::get appName=voicemail attribute=privilege
3624 10/17 11:38:04.826 WFSP APP 0 WFSysdbNdApp::get exit
5010 10/17 11:38:04.827 ACCN RTRS 0 VMAA Rej Call counter for bin 11 incremented to 8
5010 10/17 11:38:04.827 ACCN RTRS 0 CoreReportDataManager.contactRejected(). contactDataCounter size is 1
5010 10/17 11:38:04.827 ACCN EXMG 0 QueuedExecutor WorkOrder :: Mnemonic= CONTACT_REJECTED Task=com.cisco.wf.subsystems.corereporting.CoreReportDataManager$11@3e283e28 finished task
5010 10/17 11:38:04.827 ACCN EXMG 0 QueuedExecutorWorkList : WorkerName =null Current WorkOrder =null finished executing worklist
5010 10/17 11:38:04.827 ACCN EXMG 0 STANDARD-worker-7:Finished work
I see the Call is rejected because of channel busy. So, could you explain to me ?
Thuc
10-17-2013 02:01 AM
Can you provide with the configuration output of CUCM and CME
