Bronze
Buzz door open by using IP Phone???
CUCM 6.14 with SCCP, NOT SIP.
Can we use IP Phone to buzz the open??  If YES, What else component we need??
Thanks in advance!!!!
Hall of Fame Super Gold
Re: Buzz door open by using IP Phone???
You need an FXS port and a "PBX / intercom interface box".
The latter can be bought online or in telecom supplies store.
Bronze
Can you give me a little more in detail???  For example, website I can buy "PBX / intercom interface box"??  Because I found a lot of different one when I serach at google.  Dont know which is the most cost effective way or which one is the right one??
Hall of Fame Super Red
Hi Ken,
Here is one such product made by Viking. I have recommended this to a few
fellow users here who have used it successfully;
http://www.athq.com/customer/product.php?productid=21478
This would work well in conjunction with an ATA, FXS or VG202 port setup as a PLAR or Hotline to the desk phones.
Hope this helps!
Rob
Bronze
The product is for intercom, right??  Can I use that to buzz the door open by pushing the button on the phone???
Here is the situation, there is a glass door at our department, so we can see the people stand outside.  I just want to something to intergrate with our CUCM 6.12 (Skinny, NOT SIP), so we can push a button at the IP Phone to open the door.
Hi Ken,
Yes, that product is for the Intercom from the front door
This is used in conjunction with the "door strike" controller Viking c-1000b
shown below to control door access from the phone without
having to go to the door itself.
http://www.vikingelectronics.com/products/pdf/w-3000(he).pdf
http://www.vikingelectronics.com/products/pdf/c-1000b.pdf
Hope this helps!
Rob
Bronze
Rob,
Sorry bother you again, it looks like I have to use Viking W-3000 with Viking C-1000B at the same time.  However, we dont need intercom feature... we just want to buzz the door open.
Can I buzz the door open with IP Phone by JUST using Viking C-1000B??
Thanks in advance
Hi Ken,
No worries my friend
The C-1000b won't work on it's own. Wouldn't you want to be able
to check who is @ the door via the Intercom first before buzzing them in?
If this is a locked door, then it must be for a reason. The whole concept
is based on an active phone call between the door and the respective IP phone
and then using DTMF to activate the door stricker mechanism to unlock
the door. If you don't use an Intercom then there will be no way to intiate a call
to the IP phone to start the process.
Cheers!
Rob
Bronze
The door is a glass door and the visitors already through security checkpoint, so they just dont want to walk to the door and open it.
They just want to open the door without getting up.
Well, if those two products have to work together, then thats fine.  I am just wondering if there is door buzz feature without intercom module.
You could use a "DTMF Relay". Page 40 of this valuable catalog:
http://www.sandman.com/catpages.html
Community Member
Hello Rob,
       I have the exact setup like what you mentioned above.  I have a W3000 and C-1000B.   I was told by Viking that I cannot set up an ATA with this device because the ATA will not work with W3000.  In addition, they told me I need a FXO and not an FXS.  I have the FXO.   Can you give me some directions on how to configure the ATA to work with the equipment above?  Thanks in advance.
Community Member
I'm in the exact situation, were you able to find a solution ? if you did could you provide me with the product you chose and how it working ?
Community Member
I had to use a FXO card to interface with the Viking C-1000B and W3000 Door Buzzer.
On the router with FXO card:
voice-port 0/1/0
connection plar 1100 <==number to ring when someone buzzes in.
description Door Buzzer
station-id Door Buzzer
voice-port 0/1/1
dial-peer voice 1 pots
port 0/1/0
dial-peer voice 2 voip
destination-pattern 1100
session target ipv4:10.1.10.1 <== your call manager
codec g711ulaw
interface GigabitEthernet0/0
description LAN Interface
ip address 10.130.0.254 255.255.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
no mop enabled
h323-gateway voip bind srcaddr 10.130.0.254
Create a H323 Bind on your router:
     h323-gateway voip bind srcaddr 10.130.0.254 <== router IP
Create H.323 gateway on call manager and point to the router
Then if you need to transfer it to a DN that is being manned, create a partition, CSS and translation..
Hope this helps.
Community Member
hi Could you help me set up a
hi
Could you help me set up a Call Manager Express
I have
UC540
1 W-1000-EWP (connected to an FXS port)
1 RC-24
I want to do this.
Pressing the button on the intercom (W-1000-EWP) ringing all, would like a ring that someone is at the door IP phones.
Reply from any IP phone by dialing the extension 36 to the intercom
Open the door with the extension 6
For this requirement did the following:
I did a HUNT-GROUP in parallel mode and assign all extensions
a pilot number 601
When I put a FXS port coonnection-plar 601
or
601 pilot number assigned to all extensions as a secondary extension
But I have not been successful because only sounds the phone every time I press the call button of the intercom.
Annex part of the configuration:
In the FXS port where I connect the intercom viking
voice-port 0/0/3
cptone MX
connection plar 601
description conexion del intercom
station-id name intercom
 station-id number 36
caller-id enable
THE HUNT-GROUP WAS SO:
voice hunt-group 10 parallel
list 20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35
pilot 601
SO WERE ALL EXTENSIONS
ephone-dn  300  dual-line
number 20 secondary 601
pickup-group 1
label YOYIS 20
description yoyis
name YOYIS
dial-peer voice 10 pots
destination-pattern 36
port 0/0/3
I'm doing wrong?
Thanks.
13143
