C200 M2 - Make the Beeping Stop
Our C200 M2 has a failed drive (replacement on the way). How do I make this thing stop beeping in the meantime? It's driving everyone insane.
Everyone's tags (6)
1 ACCEPTED SOLUTION
Re: C200 M2 - Make the Beeping Stop
Yep, Thanks for the reply. I finally found the answer here: http://www.cisco.com/en/US/products/ps10493/products_tech_note09186a0080c0e461.shtml
Protip: remember to hit next under the controller properties to get to the screen where you can disable the alarm.
Silence is golden! lol
Thanks guys
Having the same issue.  TAC said the only way was to reboot the server and change one of the options.
Hi, I have one of these servers doing the same thing. Going to call it in, but what/where is the setting to make it stop, not seeing it in BIOS and wondering if it's somewhere else. Thanks!
The audio alarm setting is normally in the onboard config of the RAID controller, which is accessible using some keyboard combination during server bootup (after BIOS, before OS loads).
Thanks guys
Hall of Fame Super Red
Thanks for posting back Anthony +5
This will likely save some migraines out there.
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
2334
