C2901 - CME - BACD
Having issues with the BACD script, albeit a wierd error.
When I call "751" from a local softphone on the CME, the menu/script works without issues.
However when I call from an external phone, I dont hear the menu, and the call disconnects after 15 seconds.
Relevant config:
application
service menu-Queue flash:bacdprompts/app-b-acd-3.0.0.2.tcl
  param aa-hunt1 753
  param aa-hunt2 754
  param number-of-hunt-grps 4
  param aa-hunt3 755
  param aa-hunt4 756
service night-Queue flash:bacdprompts/app-b-acd-3.0.0.2.tcl
  param aa-hunt1 750
service menu-dan flash:bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  paramspace english language en
  param menu-timeout 0
  paramspace english index 1
  paramspace english location flash:/bacdprompts/
  param handoff-string menu-dan
  param voice-mail 761
  param welcome-prompt _bacd_welcome.au
  param aa-pilot 751
  param service-name menu-Queue
service menu-night flash:bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  param voice-mail 762
  param handoff-string menu-night
  param aa-pilot 752
  param service-name night-Queue
  paramspace english location flash:/bacdnight/
  param number-of-hunt-grps 1
dial-peer voice 501 voip
description menu_dan
service menu-dan
destination-pattern 751
session target ipv4:192.168.13.10
incoming called-number 751
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 502 voip
description menu-night
service menu-night
destination-pattern 752
incoming called-number 752
codec g711ulaw
no vad
telephony-service
moh "flash:/bacdprompts/en_bacd_music_on_hold.au"
ephone-hunt 1 sequential
pilot 753
list 601
timeout 10
no-reg pilot
ephone-hunt 2 sequential
pilot 754
list 602
timeout 10
no-reg pilot
ephone-hunt 3 sequential
pilot 755
list 602
timeout 10
no-reg pilot
ephone-hunt 4 sequential
pilot 756
list 601
timeout 10
no-reg pilot
Debug output:
debug ccsip calls
debug voip application script
c2901#
Jun 20 21:19:36.683: //63//TCL :/tcl_PutsObjCmd: TCL B-ACD:  >>> B-ACD Service Running <<<
Jun 20 21:19:38.639: //106//TCL :/tcl_PutsObjCmd:
proc init_perCallvars
Jun 20 21:19:38.639: //106//TCL :/tcl_PutsObjCmd: preced info : 0:-1:0 ,index : 2 ,return value: 0
Jun 20 21:19:38.639: //106//TCL :/tcl_PutsObjCmd: is mlpp = 0
>>>>>>>>>legstate = lg_001<<<<<<<<<<<
Jun 20 21:19:38.639: //106//TCL :/tcl_PutsObjCmd: TCL AA: ++ Playing Welcome Prompt and options menu ++
Jun 20 21:19:38.671: //104/7A1899AD80A6/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x3257CCE0
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : NO
Calling Number           : 12345678
Called Number            : 987654321
Source IP Address (Sig  ): 192.168.13.10
Destn SIP Req Addr:Port  : 12.34.56.78:5060
Destn SIP Resp Addr:Port : 12.34.56.78:5060
Destination Name         : 12.34.56.78
Jun 20 21:19:38.671: //104/7A1899AD80A6/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.13.10
Source IP Port    (Media): 16442
Destn  IP Address (Media): 33.44.55.66
Destn  IP Port    (Media): 51036
Orig Destn IP Address:Port (Media): [ - ]:0
Jun 20 21:19:53.803: //104/7A1899AD80A6/SIP/Call/sipSPICallInfo:
State of The Call        : STATE_DEAD
Calling Number           : 20774548
Called Number            : 840371080
Jun 20 21:19:53.803: //104/7A1899AD80A6/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Disconnect Cause (CC)    : 41
Disconnect Cause (SIP)   : 200
Everyone's tags (6)
Hall of Fame Super Silver
Re: C2901 - CME - BACD
Add incoming called-number . To one of your VoIP dial peers defined with g711 codec.
C2901 - CME - BACD
As chris said, you don't have dial-peer for incoming call. Therefore, you are matching default inbound dial-peer which doesn't support TCL.
You need to have inbound dial-peer with service assigned to it.
"If you find this post useful, please rate it"
These are my dial-peers:
Correct me if im wrong, but dialpeer 501 and 502 have the service assigned to them, and also the incomming called number?
ephone-dn  86  dual-line
number 750 no-reg both
call-forward all 751
call-forward night-service 752
night-service bell
voice translation-rule 1000
rule 1 /^/ /0/
voice translation-rule 1001
rule 1 /.+/ /750/
voice translation-profile incoming_sip
translate calling 1000
translate called 1001
dial-peer voice 1 voip
description *** Incoming call to  - -- Generic -- - SIP Trunk ***
translation-profile incoming incoming_sip
session protocol sipv2
session target sip-server
codec g711ulaw
dial-peer voice 2 voip
description **Outgoing Call to SIP Trunk**
translation-profile outgoing outgoing_sip
destination-pattern 0T
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
codec g711ulaw
dial-peer voice 6001 voip
destination-pattern 0[1-9].......
dtmf-relay rtp-nte
no vad
codec g711ulaw
dial-peer voice 6002 voip
destination-pattern 000T
dtmf-relay rtp-nte
no vad
codec g711ulaw
dial-peer voice 7000 voip
destination-pattern 4..
video codec h263
session target ipv4:192.168.1.9
incoming called-number 6..
codec g711ulaw
service menu-dan
codec g711ulaw
no vad
service menu-night
codec g711ulaw
no vad
VIP Super Bronze
C2901 - CME - BACD
Do  debug voip ccapi inout . And confirm what dial-peer the call from outside is matching? If the number called from outside is not 751 and its translated to 751 by your xlation rule then the dial-peer that will be matched first is dial-peer 1. Now the issue with this is that dial-peer 1 is a sip dial-peer and the dial-peer to your BACD is h323 leg. So you need to enable CUBE for that to work.
So I suggest you do debug voip ccapi inout. Check the number you receive when you call 751 from outside and then configure a dial-peer with incoming called number to match that. And on that dial-peer configure g711 codec.
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Just one thing I would like to clarify which I can see it missed.
TCL applications should be applied on incoming dial-peers or ephones. It won't triggered if applied on outbound dial-peers or ephones.
when you are doing call forwarding to 751, TCL isn't triggered since the matched dial-peer is for 751 is outbound.
However, if you try to call 751 from your h323 trunk directly, you will see it working fine.
You need to work it out based on this concept. To apply TCL on dial-peer use "service " command while to apply it on ephone, use "application " command.
803
