07-01-2013 08:05 AM - edited 03-16-2019 06:09 PM
i am very confused how CIPC can register with CME through internet
if i have CIPC on home PC and i want to register into C2921-CME
can any one tell me what is the possible scenarios to make CIPC login into CME through internet what is the pre-requists for this ??
is the only solution is with VPN ,,am i wrong in this assumption ??
the configuration of CIPC only have TFTP server IP
appreciate any help
07-01-2013 08:21 AM
Yes, you need to use VPN.
07-01-2013 10:04 AM
Hi Paolo,
So i must use C2921-VSEC/K9 instead of C2921-CME-SRST/K9 and use Cisco VPN client on CIPC PC
is there any recommendation about models to be used ??
Thanks for your help
07-01-2013 11:15 AM
You can use either and add the complementing license.
07-01-2013 11:45 AM
Hi Paolo,
thanks again
what do u mean by complementing license?? , pleasae clarify this point
and how can i use botth of them??
is C2921-VSEC/K9 the router model that support VPN and other security features and this C2921-CME-SRST/K9 doesn't support this
07-01-2013 03:59 PM
All models supports everything. You just add licenses for needed features.
You should contact a Cisco reseller for further support. Do not try do youself, becaus ordering, design and configuration are not meant to be done by the end user.
