Highlighted
Community Member
C887VA Voice with SIP Server
Helo
i want to get ready the Cisco C887VA voice in our infrastructure
we want to use the Device  as cpe . The Router should register the Phonenumber on our Sip (Ser) System
the registration is working right
the Call from outside to the Router is working too
but i ca`t make a call from the Router (analog fxs ) to outside
what is wrong here?
i attached the config
thanks
Markus
1 REPLY
Hall of Fame Super Gold
If you can call from the outside into your phone (behind the router) just fine but not the other way, examine your NAT.  One-way-calling is normally attributed to a NAT failure.
57
