Cable for E1 link
                   Hi guys,  can someone please provide me some idea regarding to the E1 link.
E1 link for voice VWIC2-2FMT-E1/T1 --> can I use the cat5 straight trough cable to connect router to TELCO DEMARC?
E1 G703 as 2MB data link -->  should I use the crossover cable?
thanks in advance.
1 ACCEPTED SOLUTION
VIP Super Bronze
Cable for E1 link
I think it depends on what interface you have on G703. From epxerience  I think some of them come with co-ax 75 ohm interface and some traditional rj45.
If you have a co-ax interface and your provider only has rj45, then you are going to need a ballun converter as shown here
http://www.patton.com/products/product_detail.asp?id=35
Otherwise if you have a rj45 interface then you should use  cat5 cable
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Cable for E1 link
Roy,
Yes to the first question. Most people use Cat5 to connect to the Telco.
Your second question..Do you mean can you use crossover to connect e1-g703 to telco?
Cable for E1 link
Hi Aokanlawon,   thanks for the prompt reply. about  the second quesiton, I should put this way:  what type of cable used to connect to the Telco?  thanks
VIP Super Bronze
Cable for E1 link
Cable for E1 link
Hi all,
You have two option (cable):
  1. Strait UTP cable, if it's not working, then
  2. VOICE E1 cross cable - easy to make, just switch 1,2 and 4,5 pins (wires) on RJ45 connector on one side of UTP strait cable...
One of them should work
793
