CAC Implementation
I need to implement CAC between two separate clusters connected via Intercluster trunk. There is no Gatekeeper in the scenario.Do i need a Gatekeeper or is there any easy solution.
1 ACCEPTED SOLUTION
Re: CAC Implementation
please rate the helpful post
and goos luck
CAC, may seem to be complicated to implement depending on how you want to do it and how to secure the calls and dialing. If your goal is to be able to call Phones from one cluster to the other and restrict some from dialing which phone cluster to which phone cluster, partition and calling search space maybe enough though. Your intercluster trunk connection is fine if thats the case.
Dennis
try the following
creat two regons
for example
R1 and R1 chose the required codec between clusters through ICT
creat two locations
L1 and L2
assign each location amount of bandwith then assigne one location to ur internal devices and other to the ICT going to the remote Cluster
keep in minde between the site the number of calls will be limited to the smaller one i mean the one has less bandwitch two way
by the way the ICT here should be nonGateKeeper controlled!
good luck
hope this helps
Yes i also figured out the same solution as you mentioned. I appreciate your input and it was helpful indeed.
and goos luck
143
