calculate max concurrent calls in CUCM
What is the best way to check maximum concurrent calls ( internal + external )in CUCM ?
If we check through RTMT in Call Activity - It is per minute basis. Can we change it to per hour basis ?
Have you tried the system
Have you tried the system reports in CAR?
https://X.X.X.X/car/
X.X.X.X CUCM ip addres
Which exact report or tool
Which exact report or tool can help me get the max concurrent calls that i get in one day period?
I like to uses the "Summary
I like to uses the "Summary by Phone Number" under System Reports -> Traffic
Because I always filter the traffic according to the internal endpoint.
Real time, only with RTMT and
Real time, only with RTMT and the counters you have, you can change the time they report.
Offline, as Rolando mentions, CAR would be the best option.
If you need more info than what CAR can offer, or need to customize the reports, then you need a 3rd party billing app.
java
if this helps, please rate
www.cisco.com/go/pdi
Thanks. How to change the
Thanks. How to change the counter, to get real time stats on per hour basis ?
Sorry, it was supposed to say
Sorry, it was supposed to say that you can't change the time they report.
java
Using CAR is not possible to
Using CAR is not possible to have real time per se.
What you can do it to run the hourly report around 9:05am for example to have the stats from 08:00 - 09:00
1499
