01-18-2010 03:30 AM - edited 03-15-2019 09:05 PM
i have call accounting enabled on uc520 configured to file accounting, the file created on ftp has a size of 0k, the one on flash is good
my config is
gw-accounting file
primary ftp 10.22.64.201/uc500 username cdr password cdr1234
secondary ifs flash:uflash
acct-template callhistory-detail
maximum buffer-size 40
maximum retry-count 5
maximum fileclose-timer 300
maximum cdrflush-timer 245
cdr-format compact
after running
debug voip fileacct
debug voip dump-file-acct
i noticed the following messages after each call
WARNING: gw-accounting fact not enabled. return.
and in the debug output as if the data is being deleted after being written as such
104351: Jan 18 13:14:35.763: : add attr:8A8252A4 callID(1) 4 9733(2605)
104352: Jan 18 13:14:35.763: : add attr:8A8252B0 cdr type(2) 4 1(1)
104353: Jan 18 13:14:35.763: : add attr:8A8252BC leg type(3) 4 1(1)
104354: Jan 18 13:14:35.763: : add attr:8A8252C8 h323-conf-id(4) 34 54435C35 35911DF 9B23E064 FD9F46B0
104374: Jan 18 13:14:35.767: voice_file_acct_write:
104375: Jan 18 13:14:35.767: file_acct_write_local: message (len=450) written to file_acct:
16772 bytes leftfreeing list 877B525C0x8A825290
104376: Jan 18 13:14:35.767: : del attr8A8252A4 callID(1) 4 9733(2605)
104377: Jan 18 13:14:35.767: : del attr8A8252B0 cdr type(2) 4 1(1)
104378: Jan 18 13:14:35.767: : del attr8A8252BC leg type(3) 4 1(1)
104379: Jan 18 13:14:35.767: : del attr8A8252C8 h323-conf-id(4) 34 54435C35 35911DF 9B23E064 FD9F46B0
ios info
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.0(1)XA, RELEASE SOFTWARE (fc2)
System image file is "flash:uc500-advipservicesk9-mz.150-1.XA"
03-30-2010 01:07 PM
I have the exact same issue on a 12.4.24 (T) ISR 2811 router. A cisco TAC recommended changing the IOS version. I sincerely doubt if that will make a difference. Were you able to fix this?
03-31-2010 01:21 PM
Having exactly the same issue with our ISR2811 12.4(24) T. Zero byte log files being pushed to the FTP server. Anyone run across a fix yet?
03-31-2010 02:16 PM
CSCtb72550 Bug Details
Call Detail Record File not created in FTP Server
Symptoms: Call Detail Record (CDR) files pushed via FTP are not created on the FTP server.
Conditions: This symptom is observed when the gw-accounting file command is configured to point to an FTP server.
Workaround: Push the CDR records locally to the flash instead of to an FTP URL
Fixed-In
15.1(0.21)T
12.2(32.8.11)SX332
12.2(32.8.11)YST273.11
12.4(24)YE
15.1(24.6.26)PIL13
15.0(1)M1.7
15.1(0.2.12)PIB13
12.4(25b)M0.18
12.4(24)T3
15.1(1)XB1
15.1(0.0.10)PIL14
03-31-2010 02:19 PM
Yeah, found it right after I posted that... thanks for the prompt response.
03-31-2010 02:29 PM
You are welcome.
Please help CSC donating to Haiti by rating usefls posts clicking on the stars below.
05-24-2011 05:52 PM
Hi All,
I have a similar little problem ..
In my case, the UC500 write CDR's to my FTP server, it works great... the problem is that the files don't have title or description for fields.. it show only data from calls.
My configuration is this:
gw-accounting file
primary ftp 192.168.10.25/testcdr username cisco password cisco
maximum buffer-size 25
maximum retry-count 3
maximum fileclose-timer 65
maximum cdrflush-timer 5
cdr-format compact
Machine: Cisco UC520-8U-4FXO-K9
IOS Version: Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T2, RELEASE SOFTWARE (fc1)
uc500-advipservicesk9-mz.151-2.T2
When I put the debug commands:
1. enable
2. debug voip fileacct
3. debug voip dump-file-acct
It shows this message "gw-accounting fact not enabled".. I don't know if this is the problem...
Any help will be appreciate.
Thanks..
05-25-2011 01:10 AM
Try
cdr-format detailed
05-25-2011 07:47 AM
Hi Paolo,
I try with cdr-format detailed but the result is the same... no description on fields..no tittle..
When I run the commands
1. enable
I can see the description for each field (tittle) but in .csv not show this..
So, any help about this will be appreciate.
Thanks.
02-08-2012 11:19 PM
In the 15.2-2T, You always have to use the command file-acct reset
Try to use a script
02-08-2012 11:16 PM
The problem appears also in the 152-2.T in CME9.0.
Sometimes the IOS can send and sometimes it can't send.
regards
Antra
05-25-2011 05:25 AM
05-25-2011 07:51 AM
Hi elie,
I check your recommended document... and my configuration is the same.. step by step..
But only in one thing from the example show i can't place in my conf, because the command is'n accepted for my uc500
the line is this:
vlan internal allocation policy ascending
gw-accounting aaa
method firs
Is this mandatory ?
Thanks for your help..
05-25-2011 09:53 PM
Hi Christian
it is working for me without the commands you mentioned,
the headers are not showing also, the output is coma separated and the fields are defined in the link i provided
