Call accross SIP Trunk - intermittent failures
Call from a telcom switch via PRI into AS5400 will fail intermittently on the outbound SIP leg
Switch-->PRI-->AS5400 POTS dial-peer-->voip dial-peer-->SIP Long Distance carrier
The following cause code is listed on the CCSIP debug:
Reason: Q.850;cause=102.
Here is where the disconnect occurs in the CCSIP all debug:
Jun 18 10:07:25.104 CDT: //1921806/74B317FDA53A/SIP/State/sipSPIChangeState: 0x66F46638 : State change from (STATE_SENT_INVITE, SUB)
Jun 18 10:07:35.044 CDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Jun 18 10:07:35.044 CDT: //1921806/74B317FDA53A/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
This is 12.3(11)T8
1 REPLY
Anonymous
N/A
Re: Call accross SIP Trunk - intermittent failures
Ability to check the media source address and port of incoming RTP packets, thereby enabling the remote address and port of the existing session to be updated
Enhanced interoperability in networks where NAT devices are unaware of SIP or SDP signaling
Ability to advertise endpoint presence inside or outside NAT
Ability to specify the connection role of the endpoint
http://cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080110bf9.html
422
