Community Member
Call Application - param not registered
I’m having trouble with a call application configuration on a 3845 router running 12.4 24T2, and I’m looking for some assistance.
The current configuration has been working well for us on several different models of router loaded with various versions of IOS.
On the router in question, calls come in on an FXO port and should be directed to extension 6801, but what I’m getting is two rings and then dial tone.
The extension is directly dialable from phones connected to that router and outboud calls work just fine on the FXO ports.
I did get a warning when I entered the param cm-pilot but it took the command anyway.
“Warning: parameter cm-pilot has not been registered under localinbound namespace”
Can anyone tell me how to register param cm-pilot under localinbound?  Debugging the TCL script tells me that the cm-pilot exists
002587: *Feb 16 10:49:14.066: //-1//TCL :EE7063AC00000:/tcl_InfotagObjCmd:  infotag get cfg_avpair_exists cm-pilot
002588: *Feb 16 10:49:14.066: //-1//TCL :EE7063AC00000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists cm-pilot
002589: *Feb 16 10:49:14.066: //-1//AFW_:EE7063AC00000:/vtr_cf_avpair_exists: argc 3 argindex 2
Config on the router:
application
service localinbound flash:srst_CISCO.2.0.0.0.tcl
  param operator 8182
  paramspace english language en
  paramspace english index 0
  param cm-pilot 6801
  paramspace english location flash:
  paramspace english prefix en
dial-peer voice 101 voip
preference 1
destination-pattern [2-8]...
voice-class codec 1
voice-class h323 1
session target ipv4:10.55.20.201
dtmf-relay h245-alphanumeric
no vad
voice-port 0/3/0
signal groundStart
description ***> DNH Line 1
station-id number 1231231234
caller-id enable
dial-peer voice 500 pots
port 0/3/0
forward-digits all
155
