Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Call Back between CUCM and Siemens
Hey team,
I have a MGCP trunk working properly.
All features are working, but the call back is working in the direction Cisco for Siemens only.
For example: If I make a call from a Cisco IP phone for analog phone via MGCP and I press call back , it´s fine! But, Siemens > Cisco I have a busy ton.
thanks.
What does the debugs saya about the disconnect cause???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hey Jaime,
I will get the debug file in a few minutes...
Debug log is below, but I don´t know If analog central is sending a request to call back.
3065 is analog phone.
10:40:32.845 |<:MGCPENDPOINT><:S0>|1,100,159,1.12789^*^S0/SU0/DS1-0@em01vg01
10:40:32.885 |SPROC analyzeMsgtransCause MessageTransCause.ms = 0, MessageTransCause.ieid = 0, PriTsp.protocol = 29, MCStatus = 0|*^*^*
10:40:34.907 |MGCPpn9d::processPriSetup - viprCgpnE164=[3065], viprCdpnE164=[4800], vcrUploadNeeded=[t]|1,100,160,1.274^10.13.1.151^*
10:40:34.907 |DbMobility: can't find remdest 3065 in map|*^*^*
10:40:34.907 |SPROC analyzeMsgtransCause MessageTransCause.ms = 0, MessageTransCause.ieid = 0, PriTsp.protocol = 29, MCStatus = 0|*^*^*
10:40:34.908 |!!ERROR!! -ConnectionManager- wait_AuDisconnectRequest :CI NOT FOUND IN TABLE,CI(29334280,0),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)|1,100,160,1.274^10.13.1.151^*
10:40:34.908 |MatrixControl:updatePartyMediaCoordinatorNodeId: party1 videoCapable=0, party 2 videocapable=0|1,100,160,1.274^10.13.1.151^*
10:40:34.913 |<:MGCPENDPOINT><:S0>|1,100,159,1.12790^*^S0/SU0/DS1-0@em01vg01
10:40:34.989 |<:MGCPENDPOINT><:S0>|1,100,159,1.12791^*^S0/SU0/DS1-0@em01vg01
10:40:34.989 |SPROC analyzeMsgtransCause MessageTransCause.ms = 0, MessageTransCause.ieid = 0, PriTsp.protocol = 29, MCStatus = 0|*^*^*
10:40:38.412 |<:MGCPENDPOINT><:S0>|1,100,159,1.12792^*^S0/SU0/DS1-0@em01vg01
10:40:53.388 |<:MGCPENDPOINT><:>|1,100,159,1.12793^*^*
10:41:02.722 |MGCPpn9d::processPriSetup - viprCgpnE164=[3065], viprCdpnE164=[4800], vcrUploadNeeded=[t]|1,100,160,1.276^10.13.1.151^*
10:41:02.722 |SdiStats: #Lines: 18 Free HWM: 6 Free HWM(total): 25|*^*^*
10:41:02.722 |DbMobility: can't find remdest 3065 in map|*^*^*
10:41:02.722 |SPROC analyzeMsgtransCause MessageTransCause.ms = 0, MessageTransCause.ieid = 0, PriTsp.protocol = 29, MCStatus = 0|*^*^*
10:41:02.725 |!!ERROR!! -ConnectionManager- wait_AuDisconnectRequest :CI NOT FOUND IN TABLE,CI(29334282,0),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)|1,100,160,1.276^10.13.1.151^*
10:41:02.725 |MatrixControl:updatePartyMediaCoordinatorNodeId: party1 videoCapable=0, party 2 videocapable=0|1,100,160,1.276^10.13.1.151^*
10:41:02.730 |<:MGCPENDPOINT><:S0>|1,100,159,1.12794^*^S0/SU0/DS1-0@em01vg01
10:41:02.848 |<:MGCPENDPOINT><:S0>|1,100,159,1.12795^*^S0/SU0/DS1-0@em01vg01
10:40:15.744 |<:MGCPENDPOINT><:S0>|1,100,159,1.12786^*^S0/SU0/DS1-0@em01vg01
10:40:15.984 |SPROC analyzeMsgtransCause MessageTransCause.ms = 0, MessageTransCause.ieid = 0, PriTsp.protocol = 29, MCStatus = 0|*^*^*
10:40:18.840 |MGCPpn9d::processPriSetup - viprCgpnE164=[3065], viprCdpnE164=[4802], vcrUploadNeeded=[t]|1,100,160,1.271^10.13.1.151^*
10:40:18.840 |DbMobility: can't find remdest 3065 in map|*^*^*
10:40:18.840 |SPROC analyzeMsgtransCause MessageTransCause.ms = 0, MessageTransCause.ieid = 0, PriTsp.protocol = 29, MCStatus = 0|*^*^*
10:40:18.848 |<:MGCPENDPOINT><:S0>|1,100,159,1.12787^*^S0/SU0/DS1-0@em01vg01
10:40:18.850 |<:MGCPENDPOINT><:S0>|1,100,159,1.12788^*^S0/SU0/DS1-0@em01vg01
VIP Super Bronze
Jean,
You might need to check the integration document between your siemens and cucm. I know that in some integration, call back is not fully supported
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hey,
I have checked the integration document, but I my problem is the same.
thanks.
275
