Call between a SIP phone and a remote one through H.323 trunk doesn't resume after putting on hold
Hello
I have configured an H.323 trunk between an Avaya (that don't support SIP) and a CME. As the trunk goes through a WAN link I am using G729 codec for this trunk. The phones I am using in the CME side are 7841 with G711 codec. The CME has transcoding configured. Currently I am able to make calls between both sides in both ways and the audio works fine. However, when I put the call on hold in the 7841 and resume the call, the call remains up but the audio stops passing through. That doesn't happen if I configure the 7841 phones with G729 codec. It seems the problem is due to the use of transcoding. Do you know a way to make this feature (hold) work in this situation?
1 REPLY
pls post sh run below logs
pls post sh run
below logs:
deb h225 asn1
deb h245 asn1
deb voip ccapi inout
below sh command when on hold
sh sccp conn
sh voip rtp connec
sh call active voice br (run this multiple times when on hold)
81
