Call between two routers does not complete
Colin Higgins
Level 2
Level 2
We have an Avaya PBX that needs to talk to an analog phone of a FXS port on a remote 2851 voice router.
The Avaya is hanging off a FXO port on a 2851 router with a four port FXO/FXS card. The routers talk to each other via IP through the corporate network, and no firewalls are involved.
When I try to call the remote phone through the PBX, it rings, the person picks up, but they don't hear anything. On my side it keeps ringing.
When I do a show dial-peer voice summary, I see the OPER PREFIX as up, the proper dest-pattern, port etc. When someone picks up the remote phone, I see voice port 2/0 go off-hook. However, if I try to look at the RTP stream, it is inactive (obviously).
Here is the config for the router connected to the Avaya PBX
voice-card 0
no dspfarm
interface GigabitEthernet0/0
description Uplink to Sublevel Voice_SW_3550
ip address 172.25.199.5 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 172.25.199.1
no ip http server
no ip http secure-server
control-plane
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/0/4
voice-port 2/0/5
voice-port 2/0/6
voice-port 2/0/7
voice-port 2/0/8
voice-port 2/0/9
voice-port 2/0/10
voice-port 2/0/11
voice-port 2/0/12
voice-port 2/0/13
voice-port 2/0/14
voice-port 2/0/15
voice-port 2/0/16
voice-port 2/0/17
voice-port 2/0/18
voice-port 2/0/20
voice-port 2/0/21
voice-port 2/0/22
voice-port 2/0/23
connection plar 2099
dial-peer voice 2099 voip
destination-pattern 2099
session target ipv4:172.25.76.5
incoming called-number .
dial-peer voice 100 pots
destination-pattern 91[2-9]..[2-9]......
port 2/0/23
forward-digits all
dial-peer voice 101 pots
destination-pattern [0-8]...
port 2/0/23
And the remote Router with the analog phone hanging off port 2/0
description Uplink to 00-Central-3750-48-I
ip address 172.25.76.5 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 172.25.76.1
no ip http server
control-plane
voice-port 2/0/0
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/0/4
voice-port 2/0/5
voice-port 2/0/6
voice-port 2/0/7
voice-port 2/0/8
voice-port 2/0/9
voice-port 2/0/10
voice-port 2/0/11
voice-port 2/0/12
voice-port 2/0/13
voice-port 2/0/14
voice-port 2/0/15
dial-peer voice 2099 pots
port 2/0/0
dial-peer voice 100 voip
session target ipv4:172.25.199.5
incoming called-number 2099
dial-peer voice 101 voip
As I am not familiar with Avaya, and voice is not my main area, any advice would be great. Thanks
Hope you enabled all the debugs I requested. I don't see H245 negotiation happening. Could you try disabling h245 tunneling on BOTH routers
voice service voice
h323
h245 tunnel disable    <--- hidden command so ? will not work
Also add "voice call send-alert" in global config.
Mohit Singh
6 Replies 6
MOHIT SINGH
In FXO port instead of connection plar use "connection plar opx" because your phone is located in remote location. Also try configuring below command on both router
voice rtp send-recv
Mohit Singh
I put
connection plar opx 2099
on the FXO port leading to the Avaya PBX
and put voice rtp send-recv
on both routers, but I am getting the same behavior. I can call the remot phone, it rings, but when the user answers, they hear nothing, and I hear ringing.
please provide below mentioned debugs from both routers. make sure you collect them together
debug voip ccapi inout
debug vpm signal
debug h225 asn1
debug h245 asn1
Mohit Singh
This is fromt the remote router
Jan 22 21:15:56 GMT: //317/3784296381A1/CCAPI/cc_api_call_proceeding:
   Interface=0x45A473AC, Progress Indication=NULL(0)
Jan 22 21:15:56 GMT: H225.0 INCOMING ENCODE BUFFER::= 28002B80060008914A00042800B500001240013C050100003784296382E111E381A39F3FEC44012E05800180018010A00180120140B50000120B60011000011E041E028188
Jan 22 21:15:56 GMT: H225.0 INCOMING PDU ::=
value H323_UserInformation ::=
      h323-uu-pdu
        h323-message-body progress :
          protocolIdentifier { 0 0 8 2250 0 4 }
          destinationInfo
            vendor
              vendor
                t35CountryCode 181
                t35Extension 0
                manufacturerCode 18
            gateway
              protocol
                voice :
                  supportedPrefixes
            mc FALSE
            undefinedNode FALSE
          callIdentifier
            guid '3784296382E111E381A39F3FEC44012E'H
          multipleCalls TRUE
          maintainConnection TRUE
        h245Tunneling TRUE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '60011000011E041E028188'H
Jan 22 21:15:56 GMT: H225 NONSTD INCOMING ENCODE BUFFER::= 60011000011E041E028188
Jan 22 21:15:56 GMT: H225 NONSTD INCOMING PDU ::=
value H323_UU_NonStdInfo ::=
      version 16
      protoParam qsigNonStdInfo :
        iei 30
        rawMesg '1E028188'H
Jan 22 21:15:56 GMT: //317/3784296381A1/CCAPI/cc_api_call_cut_progress:
   Interface=0x45A473AC, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
   Call Entry(Responsed=TRUE)
Jan 22 21:15:56 GMT: //316/3784296381A1/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(AlertSent=FALSE)
Jan 22 21:15:56 GMT: //316/3784296381A1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=316
Jan 22 21:15:56 GMT: //316/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x44E69794, callID1=0x13C, callID2=0x13D, tag=0x0)
Jan 22 21:15:56 GMT: //316/3784296381A1/CCAPI/ccConferenceCreate:
   Conference Id=0x44E69794, Call Id1=316, Call Id2=317, Tag=0x0
Jan 22 21:15:56 GMT: htsp_call_bridged invoked
Jan 22 21:15:56 GMT: //316/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x65, Source Interface=0x45E7B524, Source Call Id=316,
   Destination Call Id=317, Disposition=0x0, Tag=0xFFFFFFFF
Jan 22 21:15:56 GMT: //317/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jan 22 21:15:56 GMT: cc_api_get_xcode_stream : 4160
Jan 22 21:15:56 GMT: //317/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x65, Source Interface=0x45A0A0A4, Source Call Id=317,
   Destination Call Id=316, Disposition=0x0, Tag=0x0
Jan 22 21:15:56 GMT: //316/3784296381A1/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x65, Destination Call Id=317)
Jan 22 21:15:56 GMT: //317/3784296381A1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x65, Destination Call Id=316)htsp_progress_notify
Jan 22 21:15:56 GMT: //316/3784296381A1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x45A0A0A4, Destination Call Id=317, Source Call Id=316,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=250(ms), Fax Nom=300(ms))
Jan 22 21:15:56 GMT: //316/3784296381A1/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x65, Call Id1=316, Call Id2=317
Jan 22 21:15:56 GMT: //317/3784296381A1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x45E7B524, Destination Call Id=316, Source Call Id=317,
   Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
Jan 22 21:15:56 GMT: //317/3784296381A1/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=9694)
Jan 22 21:15:56 GMT: //316/3784296381A1/CCAPI/cc_api_caps_ack:
Jan 22 21:15:56 GMT: //316/3784296381A1/CCAPI/cc_api_voice_mode_event:
   Call Id=316
   Call Entry(Context=0x4639BD18)
Jan 22 21:15:56 GMT: htsp_process_event: [2/0/23, FXOLS_PROCEEDING, E_HTSP_VOICE_CUT_THROUGH]fxols_proc_voice
Jan 22 21:16:02 GMT: htsp_process_event: [2/0/23, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER]fxols_disc_confirm
Jan 22 21:16:02 GMT: htsp_timer_stop
Jan 22 21:16:02 GMT: htsp_timer_stop2
Jan 22 21:16:02 GMT: htsp_timer_stop3
Jan 22 21:16:02 GMT: //316/3784296381A1/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x45E7B524, Call Id=316
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jan 22 21:16:02 GMT: //316/3784296381A1/CCAPI/ccConferenceDestroy:
   Conference Id=0x65, Tag=0x0
Jan 22 21:16:02 GMT: //316/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=317, Disposition=0x0, Tag=0x0
Jan 22 21:16:02 GMT: //317/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jan 22 21:16:02 GMT: //316/3784296381A1/CCAPI/cc_generic_bridge_done:
Jan 22 21:16:02 GMT: //317/3784296381A1/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jan 22 21:16:02 GMT: //317/3784296381A1/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jan 22 21:16:02 GMT: //316/3784296381A1/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jan 22 21:16:02 GMT: //316/3784296381A1/CCAPI/cc_api_get_transfer_info:
Jan 22 21:16:02 GMT: H225.0 OUTGOING PDU ::=
      h323-uu-pdu
        h323-message-body releaseComplete :
          callIdentifier
        h245Tunneling TRUE
Jan 22 21:16:02 GMT: H225.0 OUTGOING ENCODE BUFFER::= 2580060008914A0004110011003784296382E111E381A39F3FEC44012E10800180
Jan 22 21:16:02 GMT: H225.0 INCOMING ENCODE BUFFER::= 2580060008914A0004110011003784296382E111E381A39F3FEC44012E10800180
Jan 22 21:16:02 GMT: H225.0 INCOMING PDU ::=
      h323-uu-pdu
          callIdentifier
        h245Tunneling TRUE
Jan 22 21:16:02 GMT: //317/3784296381A1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x45A473AC, Tag=0x0, Call Id=317,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jan 22 21:16:02 GMT: htsp_process_event: [2/0/23, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
Jan 22 21:16:02 GMT: [2/0/23] set signal state = 0x4 timestamp = 0
Jan 22 21:16:02 GMT: htsp_timer - 2000 msec
Jan 22 21:16:02 GMT: //316/3784296381A1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x45E7B524, Tag=0x0, Call Id=316,
Jan 22 21:16:04 GMT: htsp_process_event: [2/0/23, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Jan 22 21:16:04 GMT: htsp_process_event: [2/0/23, FXOLS_ONHOOK, E_DSP_SIG_0100]
voice service voice
h323
Mohit Singh
Thanks for your help
Turns out that it was a problem on the punch-down block between the router and PBX. Nevertheless, the debug commands you gave me helped me to figure it out.
