Call block issue
Hi all,
Hope you all had a great weekend
I have a query for restriction of call on the board line
Here is my issue
Whenever we get a call on the company board line number we have a unity and there is a IVR prompt to reach the exact extension ( DN) or if not then the call is transferred to the attendant console and the receptionist handles it and transfers the call to correct extension.
We have multiple offices across the country and our pub sub1 and sub2 are registered at one location but other phones from different offices across the country are registered on the same pub sub’s over wan.
We want to restrict an outside/PSTN call which hits our board line and if that caller knows the extension of other office in other state or location IP phone we want to deny the caller to reach the other location from our locations gateway.
Is there any policy which we can apply on cucm like logical portion or any restriction on unity so that the outside PSTN caller will not be able to reach other location IP phone as it will be a local call for the caller if the call is routed from our gateway?
Is there any deny allow policy for this issue?
1 REPLY
Call block issue
Two options, CSS on the VM ports, or if using CUC, the partition and CSS from that side.
I'd go with the CSS config from CUCM as it's easier to achieve what you want.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
101
