Community Member
Call block restricted calls
Hi all,
Is there a way to block incoming calls from restricted number. i have call reject rule in place on h.323 gateway but it only matches the number.
1 REPLY
If you mean calls without a caller ID then yes, you can search CSC for instructions on how to do this as this has been asked many times before.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
412
