Community Member
Call Block
I've configured Call Block to any mobile number, by means of the prefix that needs to be dialed to place calls to mobile numbers. Problem is that some users need to be able to call their Supervisor on their mobile number. How can we override the block to allow access to predefined list of mobile numbers ?
Re: Call Block
create route patterns that match the specific mobiles you need to call
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Re: Call Block
Hi Jaime, Just creating a route pattern with the mobile of supervisor is enough, or we have to do some other configuratin. pls give the full config info.
Esa
Community Member
Re: Call Block
Hi, my apologies I shoud've mentioned that is a CME 4.0 installation, so route patterns is probably not available.
Re: Call Block
create dial-peers that match the exact mobiles you need to call, same thing just using CME terminology
java
java
Community Member
Re: Call Block
Hi, created the dp but this doen not work. The block pattern looks for the 0, and the mobile number starts with 0.
here is my config:
after-hours block pattern 1 0
dial-peer voice 200 pots
description Test block override
destination-pattern 0824476951
port 0/0/0:15
any ideas ?
316
