Call Blocking ccme
May i have forced authorization code on ccme?, i meam, when a user dialed a blocked pattern he expect to receive a tone indicating to use an acces code (like ccm or any other pbx). I've been blocking calls with after hours commands and login in the phone before dialing a blocked pattern.
1 REPLY
Hall of Fame Super Gold
Re: Call Blocking ccme
if you want a feature in which the tone is played after entering the blocked number, and the pin is to be entered after the numbers, CME doesn't have that. Only a TCL/IVR script could do that.
On the other hand, users that have a pin are supposed to know how to use it so they can unlock the phone or prepend it to the number depending how you want things to work.
Hope this helps, please rate post if it dies!
104
