Call Blocking
How do I block incoming calls to our IP Telephony, Cisco
Re: Call Blocking
call blocking based on ANI can only be done using H323
you need to provide more info
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Call Blocking
It is H323, we are receiving calls from 8776421263 that we want to block. The call sare coming into a DID for a user that wanrts this blocked, what to do ???
Re: Call Blocking
First, create a translation rule that will identify the incoming call:
voice translation-rule 1
rule 1 reject /8776421263/
Then associate it with a translation profile:
voice translation profile call_block_profile
translate calling 1
Then place that translation profile into your inbound dial-peer. It you don't have one defined, create one using the incoming called-number dial-peer command, as so:
dial-peer voice 111 pots
incoming called-number .
call-block translation-profile incoming call_block_profile
call-block disconnect-cause incoming invalid_number
The call-block command allows the gateway to give a disconnect message rather than just a fast busy.
Re: Call Blocking
Sweet I was stuck at the voice trans profile...Thanks, I'll give her a try.
503
