Call cannot be transfer to an IP Phone through WAN using Tcl Script
IPPhone--CCM--Voice GW(HQ)--WAN--Voice GW(Branch)---PSTN
When a call arrives from the PSTN, Tcl script will run but when the user enter the extension it will not transfer to an IP Phone
Following are the dialpeers configured on Voice GW(Branch) Router
dial-peer voice 111 pots
service aa --------------> (AA Tcl Script)
incoming called-number 100 ----> (100 IS Tcl Pilot number)
direct-inward-dial
port 0/0/0
dial-peer voice 3000 voip
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 3001 voip
destination-pattern 100 ----> (100 IS Tcl Pilot number)
session target ipv4:10.120.150.2 ---> (IP Address of Voice GW(Branch Router)
codec g711ulaw
dial-peer voice 3004 voip
destination-pattern ....
session target ipv4:10.120.200.11 ---> (IP Address of CCM)
codec g711ulaw
I have also included the following commands in VoiceGW(Branch) but it's not working
voice service voip
Hall of Fame Super Gold
Re: Call cannot be transfer to an IP Phone through WAN using Tcl
You need special code in tcl/ivr to handle transfers. For example, look at one script that I wrote:
http://pbevila.fastmail.fm/public/number2name.tcl
hope this helps, please rate post if it does!
I have checked but it didn't work according to my requirement. If you have any other suggestions feel free to help.
I am not sure wheter your config is OK; I always use the same dialpeer for POTS and VOIP matching to AA:
dial-peer voice 500001 voip
service aa
destination-pattern 70
incoming called-number 70
codec g711ulaw
no vad
What do you see when entering 'debug voip dialpeer'? Is the right dialpeer matched?
What i've seen, Tcl script is running but when i enter the extension it will not transfer the call to an IPPhone(No Match). I create a voip dial-peer with destination pattern .... and session target ipv4:(CCM IP) but it's not working.
Hi, as mentioned above, transfers from tcl/ivr scripts requires special code. In the code is not there, transfer will not work.
138
