Community Member
Call classification & destinctive ringing
We are using CUCM 8.6 and want to distinguish internal from external calls. We need this only for the line settings (external: forward on busy, no answer, etc.).
As soon as I turn the call classification on "offnet" external calls ringing twice/double and internal calls normal. There must be a solution where I switch the call classification on offnet without change the ringing.
Thanks or support/help
The only method on which you can change the ring for internal/external calls is via the call classification and it only changes the cadence of the ringtone.
There's no way to configure ringtone based on CFB, CFNA, etc. It's either classified as internal or external.
Unfortunately if you want to change the call classification it will affect the ringtone cadence and there's no way to prevent that from happening.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
thank' for your answer.
so there's no way to switch the call classification "offnet" and edit the cadence so that the external ringtone does not sound different from internal one?
620
