Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
call_cleared: VOICE ERROR: Bearer capability not available
Hi all,
IP telephony and Fax over IP works on our router.
We can make voice calls without problem, receive faxes without problem but when we try to send fax, it does not enter the correct dial peers and cannot be sent.
When we open the isdn q931 debugs, we get the following error:
**ERROR**: call_cleared: VOICE ERROR: Bearer capability not available(0x3A): bchan -1, call id 0x805F
What can be the reason?
Thanks for your helps.
Everyone's tags (6)
Re: call_cleared: VOICE ERROR: Bearer capability not available
This may require further information to be gathered including call debugs.  I would recommend opening a TAC case.
Ok, we solved the issue.
Somehow the calling number info is not sent out and the call is dropped at the exchange office of the Telcom.
We created a translation profile and applied it to the voice-port, which solved the problem.
3771
