Showing results forĀ
Search instead forĀ
Did you mean:Ā
Call coming on second line getting the beep sound as well as voice cracking at that time
rajat00700
I have configured a hunt group with broadcast with the all user in the hunt group sharing the same 6 lines on there  7965 phones. When call came on the first line and the first user is busy on call another call come on the hunt it land on the second line at that time the fist person who is on call hear the beep sound and there is voice cracking at same time. There are two question :
1) Had anyone faces the same problem?
2) Can we restrict the beep sound when call came on second line?
Chris Deren
Yes, you can set the Ring Active policy to Disabled on the DN.
HTH,
Chris
Chris Deren
HTH,
Chris
Chris Its working fine when call is landing on the same line.But when the call is landing on another line of phone I am still getting the beep.
Rob Huffman
Hi Rajat,
You would need to use the setting that Chris kindly gave you on all
the secondary DN's on the IP phone
Cheers!
Rob
"Everything is broken" - Bob Dylan
rajat00700
Thanks--- Chris and Rob.
I implemented it  on the IP Phones  There is no beep sound now.
