call conferencing
I have a problem with making a conference call. I already have a cisco conference bridge software configured and i expect that call conferencing should work. But when I initiate an ah hoc conferncing, it displays "No Conference Bridge". What could the problem be?
1 ACCEPTED SOLUTION
Silver
Re: call conferencing
On the Phone Configuration page, check if the phone is assigned to the correct Device pool (go to that Device pool and see if the Media Ressource List is the right one).
here are the steps that should be taken to config a MGL:
Step 1
Create a media resource group.
Step 2
Assign device to the media resource group. (Order has no significance.)
Step 3
Create a media resource group list. (Order has significance.)
Step 4
Assign a media resource group to a media resource group list.
Step 5
Assign a media resource group list to a device or device pool.
Silver
Ensure first that the Conference Bridge is registred with the Callmanager. Then you should check if the Device Pool associated with your Phone have the Media Ressource Group in it, which include the COnf Bridge.
Karzazi
Hi karzazi,
The conference bridge is registered with the Callmanager. How do I go about checking if the Device pool associated with your Phone have the Media Ressource Group in it? Thanks as I await your reply.
Silver
Step 1
Step 2
Step 3
Step 4
Step 5
Silver
Also check if the Cisco IP Voice Media Streaming Service is started.
Hi Kaezazi,
I have just solved the problems with the information you provided. I really appreciate yr contribution. Thanks a lot.
I also have this issue of two 7961 IP phones having a different time from other 7940 (ten) IP phones. All twelve phones are in the same device pool and are suppose to have the same time irrespective of the phone model,but it's not so. When the 7940s have 1.30pm on them, the two 7961s will have 12.30pm(1 hr behind real time). what could be the cause.
Silver
Did you tried resetting the Phones manually? Which firmware version?
242
