Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Call Control Discovery Dn Updating...
I currently have ccd setup between two instances of CME.
When I modify a dn-block to add/remove a pattern, the router doesn't seem to change what is published to the other router until the router is completely restarted. Has anyone else run across this? I was under the impression that you should be able to add and remove patterns under a dn-block and the changes would be immediately published.
178
