Call Detail Recording - CME
I have a customer with an existing setup
and we may be changing the PBX to a CME system.
PBX CDR output ----> 3rd party software captures output reformats it and outputs it to ----> Billing software
I have been trying to setup CDR logging to a syslog server for over a week now with no success, all I want to do is capture the CDR output from the CME router so I can show the sample to the 3rd pary developer to see if they can modify there software to capture it.
There is not much help regarding setting up logging CDR output on ciscos site.
Hall of Fame Super Gold
Re: Call Detail Recording - CME
Hi Mark,
I'm about to setup something like this myself, and the best document I've found so far is:
http://cisco.com/en/US/products/sw/iosswrel/ps5187/prod_troubleshooting_guide_chapter09186a00805584f3.html
At the begginging there is an example using voice class and accounting template.
Did you ever get anywhere with this ?
I haven't set the raw CDR logging as described in the manual, but have no doubt it works as expected.
For a more complete approach to the problem we are evaluating a third party CDR and billing application by Stonevoice:
http://stonevoice.it/Products/AccountingBilling/tabid/767/Default.aspx
225
