Call directly without pressing 9 or 0
Yazen Alaa
First Question :
How i can call directly without pressing 0 or 9 on the phone ?? i have h323 protocol
this is POTS configuration in My gateway :
dial-peer voice 11 pots
destination-pattern 9.T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/3/0:15
All route Pattern
9.18xxxxxx without predot
how i can do it without pressing 9 or 0 , just remove 9 from gateway and dial-peer and thats all ???
Second Question is :
I have Fake Extenstions (not DID extension) , i need somebody has a fake extenstion call out side , will do through some DID extesntion , i will use EXternal mask or translation pattern or num-exp , Note : SIP trunk using from TElco side  (not E1 or FXO ) from my side
ex:
fake extention : 401 , when call out side. go through
22270850
solution is
num-exp 4.. 222708..
it is right
thanks and regards
mkchandak
For the first Q: Yes, removing 9 from the dial-peer will do the trick, but this is not recommended as when you have a pattern with T, it means match any number of digits, which means if anyone would dial an incoorect number (Internal Ext) the router would try to send a call through the voice gateway. If you plan to use have call routing seting without using a 9 or 0 dial, you should have dial-peers setup to match specific 10 digit for LD and 7 digit for Local starting with [2-9]. You'd need a similiar dial-peer for Intl calls.
2nd Question:
Yes, you can do a num-exp compared to translation-rule. Though if you want to have a better control on the translation it you might want to use translation-rule. A thread you could read to get more info on both of them:
https://supportforums.cisco.com/thread/2039487
HTHs
