Community Member
Call Disconnect after 30Min
a costumer has an analog phone connected to an ata186.
When he is calling out and the call lasts longer den 30Min , the call gets automaticaly disconnected.
The IP-Phones work without problems.
Is there a timer which disconnects calls after a period of time, especially for ata's ?
I found a maximum call duration timer, but that timer is set on 360Min.
Thanks for help
Silver
Re: Call Disconnect after 30Min
On the router that the ATA is conencted to do this:
show voice call sum
Make a test call.
continue repeating this command: show voice call sum.
The output it generates should you an indication about the problem.
Community Member
Was there a solution found regarding this issue? I'm currently using ATA186 in conjuction to a polycom SoundStation2W. Calls are drop consistantly. But if I place an IP conference phone on that same port there are no problem.s
Community Member
I'm sorry but no solution was found.
Community Member
I am having the same issue, did anyone find a solution yet?
Community Member
We were having a problem with ATA's and after 30 minutes it would reset, thus dropping the call.
What we found (I read the answer somewhere) that it was because we only had one of the two ports on the ATA configured. We configured both ports on the ATA and this resolved our issue.
Hope this helps you (we had issues with this for quite a while before tracking it down).
Jon
Community Member
Did someone already call TAC about this issue?
This sounds like bug, isn't it?
Nick
Community Member
Dear All,
Yes, it is CM bug, it was found in CM 5.1(3)Es1106, after I upgraded CM to ES4102, this issue is fixed, the ATA does not drop call after upgrade proces.
Michael.
Community Member
Hello Iwai
BugID was not found though the release note of "ES4102" was seen. Please teach bugID.
Community Member
I don't know the bug ID in ES1106, but the issue was solved after the system was upgraded to ES4102.
VIP Super Bronze
I am surprised its a bug, it actually is a configuraion issue on the ATA! You need to configure the second port on the ATA, otherwise in the middle of a call, the ATA attempts to configure the 2nd port and resets itself, hence your call drops. I have had th is problem with one of my customer and the solution was to configure the 2nd port on the ATA
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
I have an ATA with the same problem on 6.1.3. I will config the second port and see if it goes away.
Community Member
Thanks for everyone
It has recovered when the second port is set :D
Community Member
Yes configuring the 2nd port fixed for me.
Community Member
How did you configure the second port? I did with a number that is not used in my pool of #'s and it still drops after 20 minutes now, weird?
Community Member
I just configured it with the same number as the 1st port.
Community Member
Thanks for the reply, I found out in my case the problem was related to the firmware of the ATA. I upgraded it to 3
.2.4 and it works great now. Thanks again.
Community Member
Try increasing the tcp timeout at PIX if it is in between.
3228
