11-08-2008 11:17 PM - edited 03-15-2019 02:25 PM
hi everybody
i have a cme4.1 site with unity express
for some of the incoming calls, the call gets disconnected as soon as the reciever picks up the call. i have fxo lines only
i am attaching the debug voice ccapi inout and configuration with this mail
as the company is a support centre the problem is very severe to the business
thanks in advance and expects an earliest reply
11-13-2008 08:50 AM
Can you try the connection plar configuration and remove connection plar opx and see if it makes a difference?
With plar opx, the FXO port does not go offhook (on an incoming call) until the IP phone target (of the plar opx) answers. The call from the FXO to IP phone is triggered by the detection of ringing input to the FXO (by the C.O). The call to the IP phone is cancelled when the FXO port no longer detects ringing.
11-16-2008 01:02 AM
hi
thanks
it is like they are having six fxo lines, every calls needed to be forwarded to a receptionist
since he can attend one call at a time, six lines are configured on his phone. Also those six lines are obverlayed on other phones so if the receptionist is busy the others can pick the call up
this is the requirement for the customer, so i cant remove the plar option or is there any other way i can do this
thanks in advance
