09-19-2013 08:20 AM - edited 03-16-2019 07:27 PM
Hello All,
We have an issue with our H323 gateway for a number which disconnects twice ofThrice and then connects, i have the logs attached for you. Please look into it and give me your findings
When call connects successfully:-
Connect Successfully: 022495: Sep 19 15:02:33.889: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x006F
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1838D
Preferred, Channel 13
Calling Party Number i = 0x1181, '18664223399'
Plan:ISDN, Type:International
Called Party Number i = 0x81, '1111'
Plan:ISDN, Type:Unknown
022496: Sep 19 15:02:33.905: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x806F
Channel ID i = 0xA9838D
Exclusive, Channel 13
022497: Sep 19 15:02:34.373: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x806F
022498: Sep 19 15:02:34.405: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x006F
022499: Sep 19 15:02:35.365: ISDN Se0/0/0:15 Q931: TX -> INFORMATION pd = 8 callref = 0x806F
022500: Sep 19 15:02:44.033: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x006F
Cause i = 0x8090 - Normal call clearing
022501: Sep 19 15:02:44.037: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x806F
022502: Sep 19 15:02:44.089: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x006F
When call Disconnects:
Disconnect: 022488: Sep 19 15:01:45.060: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x006E
Sending Complete
Standard = CCITT
Channel ID i = 0xA1838C
Preferred, Channel 12
022489: Sep 19 15:01:45.072: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x806E
Channel ID i = 0xA9838C
Exclusive, Channel 12
022490: Sep 19 15:01:45.552: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x806E
022491: Sep 19 15:01:45.600: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x006E
022492: Sep 19 15:01:47.924: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x806E
022493: Sep 19 15:01:48.064: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x006E
022494: Sep 19 15:01:48.068: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x806E
Seems that from my gateway we are sending an information which is highlighted, we suspect it may causes this issue.
Your answer much appriciated.
Thanks.
09-19-2013 10:47 AM
Can you add a "debug voice ccapi inouu" also?
Regards.
09-19-2013 11:10 AM
A show run would be also appreciated.
Carlo
09-20-2013 02:41 PM
Did you try with the call type set to unknown instead of INT
Haitham
