Community Member
Call Disconnect Issue H323 Gateway
Hello All,
We have an issue with our H323 gateway for a number which disconnects twice ofThrice and then connects, i have the logs attached for you. Please look into it and give me your findings
When call connects successfully:-
Connect Successfully: 022495: Sep 19 15:02:33.889: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x006F
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA1838D
                Preferred, Channel 13
        Calling Party Number i = 0x1181, '18664223399'
                Plan:ISDN, Type:International
        Called Party Number i = 0x81, '1111'
                Plan:ISDN, Type:Unknown
022496: Sep 19 15:02:33.905: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x806F
        Channel ID i = 0xA9838D
                Exclusive, Channel 13
022497: Sep 19 15:02:34.373: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x806F
022498: Sep 19 15:02:34.405: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x006F
022499: Sep 19 15:02:35.365: ISDN Se0/0/0:15 Q931: TX -> INFORMATION pd = 8  callref = 0x806F
022500: Sep 19 15:02:44.033: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x006F
        Cause i = 0x8090 - Normal call clearing
022501: Sep 19 15:02:44.037: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x806F
022502: Sep 19 15:02:44.089: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x006F
When call Disconnects:
Disconnect: 022488: Sep 19 15:01:45.060: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x006E
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA1838C
                Preferred, Channel 12
022489: Sep 19 15:01:45.072: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x806E
        Channel ID i = 0xA9838C
                Exclusive, Channel 12
022490: Sep 19 15:01:45.552: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x806E
022491: Sep 19 15:01:45.600: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x006E
022492: Sep 19 15:01:47.924: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x806E
022493: Sep 19 15:01:48.064: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x006E
022494: Sep 19 15:01:48.068: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x806E
Seems that from my gateway we are sending an information which is highlighted, we suspect it may causes this issue.
Your answer much appriciated.
Thanks.
Can you add a "debug voice ccapi inouu" also?
Regards.
Re: Call Disconnect Issue H323 Gateway
A show run would be also appreciated.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Did you try with the call type set to unknown instead of INT
Haitham
433
